Electric Roof Fuse
Guest shadowseeker
Guest shadowseeker
i have an electric roof on my cabby that was added to the car before i even got it so all the wiring wasnt done by me.
the roof is run straight from the battery so dont go through the ignition but the main live from the battery has a fuse in line that has just started blowing after about 3 years of use, the fuse that was in it is a 10 amp, i have replaced the fuse with a 15 amp and it seems to work ok.
was just wondering if someone can tell me what amp fuse i should have in it and if it should be a 10 amp fuse then what would cause the fuse to just start blowing after 3 years of working ok ???
