Heater Matrix
Guest Graham
Guest Graham
Hi all as you all no am doing up my Mk 3 Cabby while today when i left it ticking over the heater matrix decide to let go . so the thing i like to now is how difficult is it to change ? any one done on on a MK 3 ?
hi graham, yea these aren't 2 bad 2 do, i'v just pulled mine out but wiv out the dash in, so so much easier.
i ave done one wiv the dash in on mine in the past & if i remember ryt u dont need 2 do any thin wiv the dash just undo the bottom bracket 4 the dash, the more room u can make the easier u'll make it 4 urself, but all u need 2 do is take off the 2 pipe's in the engine bay, but put sum rag around them 2 stop as much fluid goin in the car as poss, u'l need 2 take off the heater slider & plastic cover, 4 that pop off the 2 slider knob's unclip the plastic cover & then just 1 philip's screew b'hind the cover & then the 2 13mm bolts that hold the matrix box on, u'll find them ryt underneath the dash, the box should just drop down & out frm the dash wiv out 2 much trouble.
all that hold's the matrix in the box is 4 philip's screew's, if any1 knows off any defficulty's i'm sure they let u know, hope this is enough & get u sorted?
regards mark. :salut_gb:
Guest Graham
Hi mark
Thanks for that looks like its not to bad to get out i have bypassed the heater for now and will sort it out as and when i pick up a heater matrix
