Guest Tabobo Posted January 27, 2011 Share Posted January 27, 2011 Heya, got a M reg 1994 and basically in the cold winter weather all my locks decided it would be a great idea to frequently not work! but since they have all started working fine except the boot which no long opens at all (even when i talk sweet to it) basically just wondering if anyone knows of any methods of getting into the boot without breaking/drilling anything?? Heard about a half tennis ball technique to if anyones got any 'experience' in that, appreciate some feedback, Cheers! Quote Link to comment Share on other sites More sharing options...
Guest planetrover Posted January 28, 2011 Share Posted January 28, 2011 wd40 in the lock works most of the time Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted January 28, 2011 Share Posted January 28, 2011 As well as the good old WD40, i know on the early mk5's the boot lock was of the plunger type, and if it was slighty still stuck in, the key wouldnt operate it to open the lock, if yours is this type, then it might be worth just making sure the part the key goes into is fully out and then try the key again. Quote Link to comment Share on other sites More sharing options...
Guest Tabobo Posted January 31, 2011 Share Posted January 31, 2011 Heya, thanks for the replies, should have said have tried wd40 and knocking it around a little an pulling it back n forth with the key but still no joy. Starting to get a bit irritating to now as need to mend my tail light, roof and fit new rear speakers and getting tempted to either destroy the lock or maybe cut a cabby hole through the parcel shelf area (not sure if theres chassis work underneath it though) Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 2, 2011 Share Posted February 2, 2011 Hi hope you managed to get in the boot using the key. Failing that done this on mk6 cabbie sit on back seat on driver's side grab rear seat and bend it in towards the front of the car and stick you hand in and pull the seat release and you have access to boot through the car and you can get to boot panel and take it off to look at the boot lock. Hope this help's P.S don't forget to bend seat back in to place Quote Link to comment Share on other sites More sharing options...
Guest Tuft Posted February 2, 2011 Share Posted February 2, 2011 Hi hope you managed to get in the boot using the key. Failing that done this on mk6 cabbie sit on back seat on driver's side grab rear seat and bend it in towards the front of the car and stick you hand in and pull the seat release and you have access to boot through the car and you can get to boot panel and take it off to look at the boot lock. Hope this help's P.S don't forget to bend seat back in to place I agree, if you lift the rear seat swab you'll have access to the backrest hinges. You need a torx type socket to undo the bolts but once you have you can lift the seat up enough to pull on the seat release cable. It could well be that the plastic latch located on the end of the key barrel has broken and is no longer pulling the metal rod to release the catch. Unscrew the boot trim from inside (lying on your back with a torch in your mouth lol)then get your hand in the cavity and pull directly on the rod. Have fun. I did! Quote Link to comment Share on other sites More sharing options...
Guest Tabobo Posted February 9, 2011 Share Posted February 9, 2011 Hey thanks a bunch guys, awesome tips! got into the boot via the backseats as explained which was a huge achievement! next up getting some time to open the boot and finally fix all the little snags with the ol' cabby. Will prob put another post on here once its fixed and sorted out the auto on the roof, cheers again! Quote Link to comment Share on other sites More sharing options...
Guest Angel Posted October 9, 2021 Share Posted October 9, 2021 I have the same issue but I can’t find the latch/swab Mk5 escort cab Quote Link to comment Share on other sites More sharing options...
