chaz Posted November 13, 2010 Share Posted November 13, 2010 Cab been sitting in the garage for two weeks with a flat battery, today I replaced the battery with a new one, when I turned the ignition on the pump primed and the car started first time but after a few seconds it lost revs and stalled, now the pump is not priming, all other electrics are working lights, indicators and stereo. I have checked the battery connections, on the positive I have two wires one is red thick the other one which is black and thinner looked like it was holding on with a few strands to its crimped connector, infact I gave it a pull and it came off obviously now I have no power till I fix it but could this weak connection have caused the pump not to prime, or am I just hoping for a quick fix. I appreciate any help you can give me. __________________ Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted November 13, 2010 Share Posted November 13, 2010 of course, you have the answer in your question, the pumps not going to work if you have taken its earth ( the black wire ) or the power from the pump the only things that will stop the pump working, if theres broken wires, bad earth, knackered pump, or pink relay that sits under steering colum Quote Link to comment Share on other sites More sharing options...
danmk4escort Posted November 13, 2010 Share Posted November 13, 2010 thats the fuel pump relay under the dash on the drivers side pink take the top off turn on the ignition and push the little flip terminal and u will here the fuel pump come on keep your finger on it and start her up Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 14, 2010 Share Posted November 14, 2010 there not pink tho on a mk3 are they? Quote Link to comment Share on other sites More sharing options...
chaz Posted November 17, 2010 Author Share Posted November 17, 2010 It was a loose crimp on the ring connector positive battery wire, pump is now priming , problem solved Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted November 18, 2010 Admin Share Posted November 18, 2010 easy fix then chaz thats what we like to hear Quote Link to comment Share on other sites More sharing options...
