Guest Rustler Posted October 23, 2010 Share Posted October 23, 2010 Hey Guys..can U give me a bit of "Advice" on tensioning "THE BELT" on my '92 130bhp RQB 1.8 Zetec....!!! Just replaced the timing belt ,tensioner pulley,spring,post,both idlers along with new water pump. All now 100% spot on....BUT...Do I need to tension the belt MORE than the spring tension does,..or..just tighten up the tension pulley at the point the spring holds it when the pulley is loose? I have turned the engine over by hand 1/2 doz times to ensure the belt is settled in ok.. Your advice/comments appreciated.. Thanks ..Rustler .......The Oldest Cabbier.. Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted October 23, 2010 Share Posted October 23, 2010 I have done a lot of these timing belts & I have always let the tensioner take the slack on the belt. As long as you have got the marker on the tensioner in the right place there shouldn't be a problem Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted October 24, 2010 Share Posted October 24, 2010 Hi Ian... Thanks M8 ,I get your drift, but do'nt know about "The Marker On The Tensioner" bit........had a very close look at my tensioner pulley but can't make out any MARKER,..just the bolt elongated slot for tensioning and the ALLEN key hole to enable U to move the pulley left /right.??? Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted October 24, 2010 Share Posted October 24, 2010 I think what he means is when you turn it over by hand and the timing markings stayed lined up then it's cool. You should only be able to twist the belt 90 degrees Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted October 25, 2010 Share Posted October 25, 2010 The spring should always be used when setting the tension. The tensioning should be done by allowing the spring to hold pressure on the tensioner whilst you turn the crank slightly clockwise to take up any slack around the belt. then recheck the timing after rotating it twice. When the Zetec first came out this spring did not exist. it was a modification to make sure the belts were being tensioned properly because if not the customer would complain of a noise described by Ford as a 'goose honk'. Beware the goose!!! Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted October 31, 2010 Share Posted October 31, 2010 Hey...Thanks guys for your info......It's all up together again now,with both belts renewed, new w/pump, timing pulleys,tensioner,spring and post.....plus two repainted cam pullies,a shot blasted and sprayed rocker cover in Black with polished detailing, chrome oil filler cap, and dip stick ,S/S R/Cover bolts and plug cover..All other items,hoses,air filter box and pipe,belt covers etc polished Black with "ARMORAL".. The chassis members and inner wings,alomg with the complete front section and strut mounts etc, are all in original High Gloss White, with no rust what so ever ,even the bayttery box is 98% perfect.. Really pleased with the way the engine runs and the complete engine bay looks. So thanks again ALL.. for your info ...."Defo no Goose Honks"......Rustler..."The Oldest Cabbier" Quote Link to comment Share on other sites More sharing options...
chaz Posted October 31, 2010 Share Posted October 31, 2010 You told us all about it, now show it to us. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted November 1, 2010 Share Posted November 1, 2010 Yea Chaz....When I'm able to get my old head round Photo Bucket's instructions .....without loosing the plot,.... I will!!! Quote Link to comment Share on other sites More sharing options...
