Hand Brake Light
Guest garyc
hello there can someone help me please
the other day i noticed that when i take the hand brake of the light stays on ??????
this needs sorting as its doing my head in
thanks gaz
Guest s6boy1979
Hi Mate
Have a look at the switch on the handbrake lever, it could be stuck down. They tend to be the problem with the light staying on or not coming on
  • 2 weeks later...
Guest Paul Grainger
If the fluid is down then check you brake pads. If they are badly worn then the fluid level will lower than usual. Putting new pads in will bring the level back up, and if you have topped it up before hand could cause it to spill over. Brake fluid acts like paint stripper and will need to be cleaned of straight away. A watering can full of water is good for this but use plenty of it to get it all off.
Good luck
