Mk4 All Blue Running Rich
Guest dave29
hi guys. :wink: the tick over is quite high on the cabby and sometimes when the car is hot and you try and start it the starter turns but sounds like the battery is just about dead then it fires up.would a tune up cure this.........yet another problem.damn fords pmsl. :laugh:
Guest s6boy1979
Mine is an efi and mine was running rich. Any garage that does mot's can adjust the mixture for about £20. If that doesn't sort it them the fuel pressure regulator needs adjusting at the same time which is a bit more specialised. A rolling road session is def worth doing but not cheap but they will get it running spot on or tell you if you need to replace anything to get it running how it should. The non turbo cvh's do tend to tick over not as smooth as the turbos
My grammar is really poor lol
my gramma aint great either lol.dont worry about it. thanks the the quick reply. :smile:i read somewhere on here that there is a adjustment screw on the throttle body and on the passenger side inner wing under the bonnet.......not sure what type of engine thats on though.they is a thumb type wheel adjustment screw on the passenger side i found.duno what its for though. my mot is coming up shortly n im a bit concerned about it failing on emmisions.i was thinking of one of them mobile tuning dudes to get the emissions down n make the engine run sweeter.good idea? :unsure:
Guest s6boy1979
On the efi the mixture adjuster is on the inner wing infront of the bat, can't remember exactly what it is called. Def worth getting on a machine and set up or you could ask if the garage that does the mot if they can adjust the mixture, most decent places will
guess i should,nt adjust it then lol. knowing me ill fook it up lol. :rolleyes: cheers i,ll get it tweeked before it goes in for the mot. :drivin:
One thing I forgot to ask, does the car tick over lumpy and does the engine sound tappety?
lol. did you used to own it pmsl. :laugh: yeah it does.the needle on the rev counter sits just over the 2 mark on the clocks but as the car warms up it dont do it as much.one thing i noticed when i was under the bonnet that there is a flexi hose that goes behind the front bumper thats supposed to be conected to the air box n it aint so that mite cause the tick over problem. :huh:
Guest s6boy1979
It could be worn tappets and cam as they are as soft as shit. That hose sounds like it could be a cold air feed which will make no difference but can't picture it in my head what pipe you mean lol
yeah i thinks its the cold air feed.the pipes been ripped so wont reach the air box anymore.tappets are adjustable though right? sorry im just learning bout cabbys. :blush: if the engine is knackard i,ll just stuff a new un in compleate. lol.
Guest s6boy1979
Nah they are hydraulic, so making sure you have enough of the right is a must, the engine isn't knackered and the cvh is always a bit tappety and the top end does wear out quickly if not looked after properly
well it goes well when i put me foot down. :tongue: ive heard that they are a bit tappety but there old engines so....... :salut_gb:
Guest s6boy1979
had a result with bits as well, got an fez turbo bottom end for free just need to find a machine shop to get it bored out and the crank lightened. Also got a t3 for £25 lol :banana_dance:
jammy sod lol. :laugh:
