Guest cabbydean Posted August 21, 2010 Share Posted August 21, 2010 hi all as usual replaced idle valve o2 sensor temp sensor and all other sensors still drives crap on light thrittle when warm any ideas? Quote Link to comment Share on other sites More sharing options...
Guest Rabbit Posted August 22, 2010 Share Posted August 22, 2010 try cleaning out the maf sensor with a bit of carb cleaner Quote Link to comment Share on other sites More sharing options...
Guest cabbydean Posted August 23, 2010 Share Posted August 23, 2010 tried cleaning it and replacing with diff maf still no difference Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 23, 2010 Share Posted August 23, 2010 has the brether hose that connects to the inlet from the front of the engine not got a hole in it as this is sometimes over looked and can give some great side effects??? Quote Link to comment Share on other sites More sharing options...
Guest cabbydean Posted August 23, 2010 Share Posted August 23, 2010 replaced pcv valve pipe work and tried blocking it all off still same! Quote Link to comment Share on other sites More sharing options...
Guest cabbydean Posted August 23, 2010 Share Posted August 23, 2010 begining to get fed up now runs spot on until you let foot off throttle and it coughs and under light cruising throttle its kangaroos badly also misses when you hit throttle from tickover Quote Link to comment Share on other sites More sharing options...
