Guest allanblackey@yahoo.co.uk Posted August 16, 2010 Share Posted August 16, 2010 Hi guys 1993 MK5 I'm really hoping that someone can help me. Just the other day my front windows have stopped working, but the rear ones still go up and down no problem. I am assuming that all the windows are on the same fuse but checked them anyway and none of them are blown. Any ideas what I should check and where? I'm really not mechanically minded so any help aimed at a layman would be great Cheers Allan Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted August 16, 2010 Share Posted August 16, 2010 try swapping the switches from front to back.. Quote Link to comment Share on other sites More sharing options...
Guest allanblackey@yahoo.co.uk Posted August 18, 2010 Share Posted August 18, 2010 try swapping the switches from front to back.. I tried that and still only the back windows work. So the switches are okay, and the fuses are okay - shows a supply going to fuse so I guess there's a problem between the switches and the fusebox. I assume I need to take out the front panel to get in at the wiring?! Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted August 18, 2010 Share Posted August 18, 2010 So there's no power to the front switches? If that is the case there is a problem between the fusebox and switch, like you said... Quote Link to comment Share on other sites More sharing options...
