Front Windows Not Working
Guest allanblackey@yahoo.co.uk
Hi guys
1993 MK5
I'm really hoping that someone can help me. Just the other day my front windows have stopped working, but the rear ones still go up and down no problem. I am assuming that all the windows are on the same fuse but checked them anyway and none of them are blown.
Any ideas what I should check and where? I'm really not mechanically minded so any help aimed at a layman would be great
Cheers
Allan
try swapping the switches from front to back..
I tried that and still only the back windows work. So the switches are okay, and the fuses are okay - shows a supply going to fuse so I guess there's a problem between the switches and the fusebox. I assume I need to take out the front panel to get in at the wiring?!
