Guest Brownyyyy Posted March 5, 2011 Share Posted March 5, 2011 where about is this breaker mate, im from county durham and im after some bits for my mk4 cabriolet. cheers Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 5, 2011 Share Posted March 5, 2011 where about is this breaker mate, im from county durham and im after some bits for my mk4 cabriolet. cheers gateshead-newcastle area. try, northeast-escort-breakers : 07856433383 Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 5, 2011 Share Posted March 5, 2011 Well as i had to put a days holiday in this week i managed to get a few jobs sorted on the 18 zetec namly the engine loom weeded out to just a 8 wire connect ready for the drop in when it happens. It was a much easier just than i 1st thought, well not much happened till last night when a sudden bout of dryness outside spurred me on to clearout the garage and rebuild the 1.8 back up to to ensure i have all the bits there just a new waterpump to fit and timing belt kit while the engines out, also i might put the flywheel through the blaster aswell just so its hada freshen up and i cant get the rocker cover off yet until i put the engine back on the floor as the chains are holding it in place. Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 5, 2011 Share Posted March 5, 2011 looking very well pal Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 5, 2011 Share Posted March 5, 2011 looking very well pal I just cant wait till the head gasket set gets here as i'll fit the lot then give it a quick de-coke while i'm on.then might put 2 days holiday in to give me self a long weekend and that should be it done. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 6, 2011 Share Posted March 6, 2011 (edited) Well not a major leap forward but started to make a loom up to run inside the car just extended the pig tails i had on the mk6 loom by 1 metre on the 9 wires i will be using and labelled them up with shrink wrap id no.'s, this should make for a quicker install when i get to it along with my pinout chart i made for the 9 wire install. Also managed to get my hands on a 115ps ecu,chipped key and engine bay loom for nowt today so thats more than quick enough for her indoors put that behind a consideribly lighter escort than the mk6 andit should make for quite a nippy motor? Edited March 6, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 7, 2011 Share Posted March 7, 2011 Went out and secured 300 crimp terminals and 10 fuse holders on the bay last night so there coming soon so all in all i'm about 90% there for having everything at my disposal for the drop-in. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 8, 2011 Share Posted March 8, 2011 Is that your living room carpet your working on, must be warmer than the garage!!!! Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 8, 2011 Share Posted March 8, 2011 Is that your living room carpet your working on, must be warmer than the garage!!!! Nah i was working indoors on the ironing board. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 9, 2011 Share Posted March 9, 2011 Well 300 crimp terminal connectors turned up today along with 10 inline fuse holders & a full 1.8 zetec head gasketset so 1 more step in the rite direction. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 11, 2011 Share Posted March 11, 2011 Well the deadline is set 2nd-5th of april 4days to do the conversion, as i have now put my holidays into give me a long weekend, besides its 3weeks before the 1st ford meet of the year up our way so need it running nice for then dont I??? Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 12, 2011 Share Posted March 12, 2011 (edited) Well i had to drop the motor off to get machine polished tonight then while a had a short while to myself desided to sift through 2 wiring diagrams and 2 pinout charts to make my mini fusebox/ fuse relay pack to get the engine to run as ford intended all being well i'm right??? Should only be a 9 wire connection when done. Edited March 12, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 13, 2011 Share Posted March 13, 2011 Just got a mk5 escort fusable link bracket to mount on the battery today for the main feed to the mini fusebox i made, and ordered more wire today as i'm going to make another fusebox up for the 115ps loom i got just incase i want to do another zetec conversion as i also have a 1.8 si inlet, crossover pipe and MAF with K&N. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 14, 2011 Share Posted March 14, 2011 Great work, keep it up Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 15, 2011 Share Posted March 15, 2011 Well more power cable turned up today so thats the main feed from the battery accounted for and the main earth for the mini fusebox. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 17, 2011 Share Posted March 17, 2011 Not much to report other than the flywheel got put through the blaster Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 17, 2011 Share Posted March 17, 2011 Exhaust turned up today too, not a free flowing one as its only a power flow but still its stainless and looks better than the std pea shooter, hopefully it will flow enough and not restrict the 1.8 zetec. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 17, 2011 Share Posted March 17, 2011 Looks OK m8, was the can of coke needed after getting in the kitchen!!! How many rooms have you got left now!! Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 18, 2011 Share Posted March 18, 2011 Looks OK m8, was the can of coke needed after getting in the kitchen!!! How many rooms have you got left now!! Nah i'm having a clearout on be-gay at the miunte got too much stuff as i tried to cram it all in the garage selling 2.0 zetec engine, 2.0 zvh a load of other useful zetec bits like looms and such like. then there is the orion on there too!! also won a new xr3i clutch today on e-bay £20 buy-it-now deliverd!!! bargain. Only 2 weeks to go now, bloody hope it runs 1st go cant be arsed with all the hassle of having to re-do wiring. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 18, 2011 Share Posted March 18, 2011 Well done with the clutch!, hope it does run well for you Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 18, 2011 Share Posted March 18, 2011 Well i have been looking at just incase sinarios incase it dont run for any reason so have got my eye on a none pats 18 ecu and also have a set of zx7r bike carbs and pressure reg. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 19, 2011 Share Posted March 19, 2011 Exhaust is now on what a nightmare!!!!!!!!!!!! took me 8hrs to get it on and its blowing its T*TS off will have to come off and get smootherd in exhaust putty at all the joints. Its just one of them jobs that fight you all the way but got there in the end. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted March 19, 2011 Share Posted March 19, 2011 Nice back box its huge Also liking the mini fusebox/relay pack How long till the first fire up of engine for a test? Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 19, 2011 Share Posted March 19, 2011 Nice back box its huge Also liking the mini fusebox/relay pack How long till the first fire up of engine for a test? If everything goes according to plan it should be running 2 weekends from now as i have a long weekend booked (2nd - 5th april) Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 20, 2011 Share Posted March 20, 2011 is that back box gunna sit in the bumper ok lol?? Quote Link to comment Share on other sites More sharing options...
