Guest smegward Posted July 9, 2010 Share Posted July 9, 2010 ive got a slight problem with the relay box that comes off the battery randomly driving down the road the stereo headlights clock and dash lights will go off until the next bump the come back on or if you tap the relays they come back on, so im thinking get a new relay box but where stock them??? ford didnt have a clue what i meant and ebay's confusing as im not sure which is for my car? its a 1993 xr3i mk5 cheers Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 9, 2010 Share Posted July 9, 2010 do you mean the fuse box? commen fault on mk5/6 i believe Quote Link to comment Share on other sites More sharing options...
Guest smegward Posted July 10, 2010 Share Posted July 10, 2010 i dont think its a fusebox but coming directly off the live terminal on my battery is a black box with 2 relays in then it carrys on elsewhere the wiring Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted July 10, 2010 Share Posted July 10, 2010 Thats the additional fuse bank that links directly to the live terminal on battery. Would suggest replacing the fuse themselves as the terminal itself is just flat plates inside unless there corroded. Never bought one. Worst case buy a new battery terminal and some inline fuses to replace it or go hunting for one at a scrap yard. Should be plenty there Quote Link to comment Share on other sites More sharing options...
Guest smegward Posted July 12, 2010 Share Posted July 12, 2010 cheers ill have a ganders tomorrow the lids been snapped on it and previous owners tried pushing the relays down with tie wraps Quote Link to comment Share on other sites More sharing options...
Guest smegward Posted July 18, 2010 Share Posted July 18, 2010 ive re wired the relays there spot on and havent gone off yet but now ive lost my rear passenger side sidelight and also my lights around the clocks in dash Quote Link to comment Share on other sites More sharing options...
