Guest suffolk04 Posted July 3, 2010 Share Posted July 3, 2010 How easy & whats needed to fix the oil leak? coming from where the speedo cable goes into the gearbox Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 3, 2010 Share Posted July 3, 2010 if you unscrew the speedo cable the bit that that screws into should screw out aswell (sorry i dont know what its called) easy to do and a new one should sort it, i had it before where it had broken there, hope that makes sence lol (drunk) Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted July 3, 2010 Share Posted July 3, 2010 if you unscrew the speedo cable the bit that that screws into should screw out aswell (sorry i dont know what its called) easy to do and a new one should sort it, i had it before where it had broken there, hope that makes sence lol (drunk) not really, lol. so it's a new speedo cable needed? or is there a seal to change Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 3, 2010 Share Posted July 3, 2010 no, the bit on the gearbox that the cable screws onto, you should be able to screw that out aswell after you remove the cable Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 3, 2010 Share Posted July 3, 2010 chances are that bit is broken around the thread causing it to let oil seep out Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 25, 2010 Share Posted September 25, 2010 been a while, but replaced it last month, checked this morning just out of chance, oil leaking from it again. could it be a dodgy seal or something else causing it Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted November 2, 2010 Share Posted November 2, 2010 would a new speedo cable help stop the leak? i've fitted the bit that goes into the gearbox, but its still leaking, checked the breather, but it's missing so its not that, Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted November 2, 2010 Share Posted November 2, 2010 check the oil level in the gearbox. May be too full. Can't remember but i think the speed cable has a seal built into it also. Finally i think different variants of the ib5 gearbox have the breather located in diffrent places. Late as fitted in mk6 have a plastic cap on top. Early mk3 have a pipe on the end on the box. Could the gearbox be a recon made up of slightly wrong parts? Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted November 3, 2010 Share Posted November 3, 2010 i've had the car for nearly 4 years now, its just started leaking, so think it's been built right. the breather on mine goes to the inner wing, but like i said, pipe is there, just no breather block. i'll look at the level, then change the speedo cable, fingers cross it's the cable, other wise its more £££ that i aint got Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted November 4, 2010 Share Posted November 4, 2010 The favorite thing is a blocked breather. Check to see if it has been kinked inside the chassis leg, then take it out to make sure you can blow through it ok. Good luck Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted November 7, 2010 Share Posted November 7, 2010 just ran the car, found it's leaking from the speedo cable nut. must be a seal or something on the threads that screws into the gearbox Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted November 9, 2010 Share Posted November 9, 2010 If the breather is clear and the oil level is ok then remove the tiny roll pin that sticks out of the casing just below thw speedo cable. (you will need a decent pair of side snips as it is tight). You can then pull the threaded part out of the transmission complete with the drive. There is an O ring on the piece you pull out that can be replaced. When it comes to refitting, line up the groove on the piece you pulled out so the roll pin can go back in ok, and dont tap it all the way back in just in case you need to remove it again. Good luck Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted November 9, 2010 Share Posted November 9, 2010 thanks for that, but i changed that, the unit came with a new seal, so must be a seal somewhere on the speedo cable, anyone know? Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted November 11, 2010 Share Posted November 11, 2010 None on the cable itself Quote Link to comment Share on other sites More sharing options...
Guest Mk4 Kenilworth Posted February 9, 2013 Share Posted February 9, 2013 Can anyone suggest a fix for this or know where I can get a speedo gear assembly? I've completely rebuilt the engine and transmission. It runs and sounds great, but the only fly in the ointment is this leak. I know it's not the breather nor the o' ring which is new. So it can only be coming up from inside the speedo gear, right? Or am I wrong? Does the cable's threaded section act as a seal? if so will a dab of thread sealant cure this? I'm pretty desperate cos its peeing out! Quote Link to comment Share on other sites More sharing options...
Guest Mk4 Kenilworth Posted February 10, 2013 Share Posted February 10, 2013 (edited) Problem solved, the plastic gear's shaft was badly damaged and i'm sure theres one on fleabay. Edited February 10, 2013 by Mk4 Kenilworth Quote Link to comment Share on other sites More sharing options...
Guest Mk4 Kenilworth Posted February 10, 2013 Share Posted February 10, 2013 Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted February 14, 2013 Share Posted February 14, 2013 I think I have got a speedo drive if you haven't been able to sort 1, I will check now that I am near my spare parts Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted February 14, 2013 Share Posted February 14, 2013 Quote Link to comment Share on other sites More sharing options...
Guest Mk4 Kenilworth Posted February 20, 2013 Share Posted February 20, 2013 Cheers mate, but I'd already bought one from eBay. It seams to fit ok and I've also wrapped a bit of ptfe tape round the thread to be on the safe side. Quote Link to comment Share on other sites More sharing options...
Guest chucky dozza Posted September 28, 2013 Share Posted September 28, 2013 Hey just read the comments and tbh I was looking around mine today and noticed oil on top bix and fort it was speedo thing iswell I do have bit oil on head but thats rocker cover gasket im changing Quote Link to comment Share on other sites More sharing options...
