Guest bigburger Posted June 24, 2010 Share Posted June 24, 2010 When i bought my EFI 1.6 it was lumpy as hell when idle, then discovered the ISCV was totally missing ! I got a valve and the garage fitted it today, the car ran for a few mins then stopped, they removed the valve and now the car won't idle, was misfiring and back firing ? Is it dead ? lol i really don't know, any help would be awesome ! Cheers Steve Quote Link to comment Share on other sites More sharing options...
Guest bigburger Posted June 25, 2010 Share Posted June 25, 2010 heres what i currently have Quote Link to comment Share on other sites More sharing options...
Guest bigburger Posted June 25, 2010 Share Posted June 25, 2010 here is what i bought and fitted. now the car is daffy ducked !!! Quote Link to comment Share on other sites More sharing options...
Guest bigburger Posted June 25, 2010 Share Posted June 25, 2010 here is my wee motor Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted June 26, 2010 Share Posted June 26, 2010 you sure it's the right connection and right valve for it? Quote Link to comment Share on other sites More sharing options...
Guest bigburger Posted June 26, 2010 Share Posted June 26, 2010 you sure it's the right connection and right valve for it? Nope ! lol Quote Link to comment Share on other sites More sharing options...
Guest jagman Posted September 30, 2010 Share Posted September 30, 2010 hi there mine has the same idle valve but where it mounts the are 2 identical connections. never managed to work out properly which one is supposed to be plugged in just trial error. Quote Link to comment Share on other sites More sharing options...
Guest nealbar Posted October 29, 2010 Share Posted October 29, 2010 (edited) mine just rev up high so tryed a new one but still does the same so disconnected it will it be ok or does anybody no the problem Edited October 29, 2010 by nealbar Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted October 30, 2010 Share Posted October 30, 2010 Is it plumbed it corectly? any air leaks cause big running problems. The early escorts had a Hitachi valve fitted to the air filter lid, but due to driveability issues it was modified to fit in line attached to the baulkhead instead. This is the one you have got so make sure all the pies are in the right place. Compare it to another one if you can. Good luck Quote Link to comment Share on other sites More sharing options...
allblue Posted October 30, 2010 Share Posted October 30, 2010 Can you post some pics of your engine bay, I need to see how your ISCV connects to your engine Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted October 30, 2010 Share Posted October 30, 2010 i got one of them but not attached or plumbed up engine idles abit high but fine intl u rev it when it comes down it almost cuts out but never have so far tis a bad thing but i seen a picture of one plumbed up to the air inlet/air intake oposit side to where the brake master cyclinder connects.. Quote Link to comment Share on other sites More sharing options...
