Guest Hughesey Posted May 30, 2010 Share Posted May 30, 2010 Hello, my Headlamp beams are not aligned, does anyone know how to adjust them, there are 2 plastic nuts at the back of the headlamp to adjust them horizontally and vertically, but when i have adjusted them this way, one headlamp when beam is level with the other, is way too far out of line with the indicator (as in not level) Any ideas will be welcome ;-) Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted May 30, 2010 Share Posted May 30, 2010 there is an adjuster which is a 10mm plastic screw use a spanner to adjust the light that will either pull the light in or push the light out if thats any sort of help Quote Link to comment Share on other sites More sharing options...
Guest Hughesey Posted May 30, 2010 Share Posted May 30, 2010 there is an adjuster which is a 10mm plastic screw use a spanner to adjust the light that will either pull the light in or push the light out if thats any sort of help a could give myself a right slap!,i was changing the indicators back to standard amber colour, so i thought to take them off you slackened the plastic nuts, naturally i realised after an hour that the bottom adjuster is on a ball-nut which just pulls off and the top has a plastic retaining clip, so i didnt need to touch the plastic nuts (gutted), on the other hand if ever i want to change them back to the clear ones, i will breeze it next time. i probably just need a to play with the adjusters for a few hours. Quote Link to comment Share on other sites More sharing options...
