Guest s11pyk Posted April 16, 2010 Share Posted April 16, 2010 in another thread this problem has been mentioned by myself and now reported by another, so..... i changed my clocks and now my rev counter only goes up to 3k, my car is an efi. the clocks i put in have the fuel and temp the same way round, whats goin on. someone mentioned the edis or something?? running new wires etc. this is not my strong point but i really dont want to be paying an auto electrician. help please Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 16, 2010 Share Posted April 16, 2010 I've got the same problem!!! Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 16, 2010 Share Posted April 16, 2010 we will find the cure, somehow Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 16, 2010 Share Posted April 16, 2010 The speedo worked ok until i swapped the clocks Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 17, 2010 Share Posted April 17, 2010 The speedo worked ok until i swapped the clocks mine too. its not gonna be the hardest thing in the world to sort! Quote Link to comment Share on other sites More sharing options...
iansoutham Posted April 17, 2010 Share Posted April 17, 2010 The fuel gauge and temp gauges are a year definition, not a model or engine specification. Pre 1988 had the fuel on the right, post 1988 had the fuel on the left. The reason that your rev counter is only reading half rpm is because it is only seeing half rpm. You need the rev counter from a non-EFI car, or you need to rewire the green wire on the dash clocks plug to a different pickup source within the EDIS module. I would swap the rev counter over personally. EFI (CVH and HCS-engined) cars have a specific rev counter. Same as if you put EFI clocks into a non-EFI car, as soon as you put your foot down and rev the car, the needle will flip straight past the redline and end up the wrong side of the needle-stop as it will be seeing twice the actual rpm. Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted April 17, 2010 Share Posted April 17, 2010 Is there a way to determine which clocks are which on the clocks as I have some old one's laying about was going to sell and don't want to sell to the wrong type if you get my meaning. Quote Link to comment Share on other sites More sharing options...
iansoutham Posted April 17, 2010 Share Posted April 17, 2010 The most accurate way is to take the clocks apart and get the part number from the rev counter itself and post it here. I can tell you from that. The number will be something like 88AB 17360 AA. I think some models had a different number underneath the needle spindle, but it is late and I can't remember for sure. Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted April 17, 2010 Share Posted April 17, 2010 I take it the first 2 numbers are the year ? Anyway thanks ill have a look tomorrow maybe and get back to you. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 17, 2010 Share Posted April 17, 2010 The fuel gauge and temp gauges are a year definition, not a model or engine specification. Pre 1988 had the fuel on the right, post 1988 had the fuel on the left. The reason that your rev counter is only reading half rpm is because it is only seeing half rpm. You need the rev counter from a non-EFI car, or you need to rewire the green wire on the dash clocks plug to a different pickup source within the EDIS module. I would swap the rev counter over personally. EFI (CVH and HCS-engined) cars have a specific rev counter. Same as if you put EFI clocks into a non-EFI car, as soon as you put your foot down and rev the car, the needle will flip straight past the redline and end up the wrong side of the needle-stop as it will be seeing twice the actual rpm. Mine is a 1990 efi and the clocks i took out had the fuel on the left and the clocks i put in have the fuel on the same side and are from a late efi as well, that all works fine. The rev counter that is playing up now doesn't even read half revs it goes to 1500 max. Is this just a knackered rev counter Quote Link to comment Share on other sites More sharing options...
iansoutham Posted April 19, 2010 Share Posted April 19, 2010 Mine is a 1990 efi and the clocks i took out had the fuel on the left and the clocks i put in have the fuel on the same side and are from a late efi as well, that all works fine. The rev counter that is playing up now doesn't even read half revs it goes to 1500 max. Is this just a knackered rev counter Yep, most likely the spring has gone weak. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 19, 2010 Share Posted April 19, 2010 Great!!! Cheers dude Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 19, 2010 Share Posted April 19, 2010 weak spring? can i strip the old unit and fix my replacement then? the clocks are clean themselves and i dont like white dials and all that i just want tidy working dials! Quote Link to comment Share on other sites More sharing options...
Web Development Posted 6 hours ago Share Posted 6 hours ago Web development consulting services Website development consulting services Professional web development consulting Custom web development consultancy services Expert website development consulting solutions Web design and development consulting services Full-stack web development consulting services Business web development consulting solutions Quote Link to comment Share on other sites More sharing options...
Web Development Posted 6 hours ago Share Posted 6 hours ago Custom web development services in USA USA-based custom web development services Professional custom web development services USA Affordable custom web development services in the USA Enterprise custom web development services USA Tailored web development services in the United States Custom website development services USA Expert custom web development solutions in the USA Quote Link to comment Share on other sites More sharing options...
Web Development Posted 5 hours ago Share Posted 5 hours ago Enterprise-level web development services Enterprise web application development services Scalable enterprise web development solutions Full-stack web development solutions End-to-end full stack web development services Professional full stack web application development services Quote Link to comment Share on other sites More sharing options...
