Track Control Arms
Guest lambrettaman
Guest lambrettaman
i have mk5a 3i is it poss to change wishbones to track control arms as on rs2000 if so has anybody done this mod and what parts are needed cheers
  • 2 weeks later...
Guest steelcabby
what do you mean from a mk4?? why would you want to do that? you would need to fabricate part of the sub frame or chassis to get them to fit. they ain't very good on the mk4 anyway.
if your wanting to get stronger arms. either use royal mail van arms or get some specials.
the van arms have bigger bushes that take alot more abuse. they are around £100 a set. or you can get some specials for around £300.
hope that helps?
Guest steelcabby
sorry i think i have read your topic wrong :punish:
so you want to change the lower arms/wishbones for RS2000 items??
i think they are the same chap as far as i know. but if its due to stengthening them up. the post i did above will help you out
