Guest jimmyrimm Posted February 6, 2010 Share Posted February 6, 2010 Hi.. I decided to clean the fuse box on my 1986 XR3i cab...thinking it a good idea i applied WD40 liberely over the fuse box and then cleaned the fuses and replaced some and also cleaned the relay switches. I reintalled all fuses and relay switches. I now discover that the Indicaters, Heater Fan and main Cooling Fan do not work! i have checked the relavant fuses (which are all in line next to each other) but still no response from these three things....What have i done wrong and what might i have damaged and how can i rectify the problem ? Quote Link to comment Share on other sites More sharing options...
