Pod Gauges
Guest markini5
Guest markini5
hi all, does anyone know how correctly wire in separate oil and water temp gauges, their are 1 wire from each that go some where then 3 other to light up.
also boost gauge shall i just use a tee piece from dumpvalve .
thanks
Guest markeyboy
with the pods, one wire will go from the pod to a sender unit located either in a water or oil way.
the other 3 wires, one will be an earth one will be a live supply (usually tapped into a feed which is live when the ignition is on) and the other should be illumination
cant help with the dump valve im afraid
Guest Cabbytech
I agree with Markeyboy regarding the wiring, and for the boost gauge, a tee or Y connector piece in the dump valve pipe should be fine. Fit something of a decent quality though.
