Drivers+Passengers Window Adjustment Help
Guest DEG
Hi all,
New to the escort scene but always wanted 1, picked mine up thursday morning off ebay but got a slight prob with where the windows on both sides sit i need to adjust them inwards towards the car so they sit on the rubbers currently have a 4-5mil gap at the top. Any help or pics would be great. Also its a 1990 1.6i efi cabrio where would i purchase a haynes tried ebay but unsure which one. THANKS david
mi fella
if you take off door panel there's 2 adjusters 1 at the back which moves the rear of window and 1 in the middle of the unit.
thats the one you want,it's a 10mm nut, undo it slightly and move the block, retighten and try window, keep ajusting a bit at a time untill it fits correctly.
i hope this helps
ian
Guest s11pyk
will get on to it this afternoon sounds simple enough. :biggrin:
sounds simple, but we still cant figure it out! is it the bottom one of the three, sort of centre of the door?
if anyone has any pics it would help. we're a little slow up north :crazy:
