Guest s6boy1979 Posted December 7, 2009 Share Posted December 7, 2009 Hi Please Help !!!!!!!!!!!!!!! I bought my MK4 cab last week, the last owner have fitted white dials and the temp shoots way over the red and stay's there but the car does not over heat. I have changed the temp sender but it's still the same. I have no idea what is could be, do i need to move the needle? It has an efi engine and the dials have the temp gauge on the right hand. Any help would be great. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted December 7, 2009 Share Posted December 7, 2009 Hi mate either break in wire and its earthing out. Does the needle go to the bottom when switched off?the needle might have been put back in wrong place Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted December 7, 2009 Share Posted December 7, 2009 Yeah it sits at the bottom when the ignition is off. I took the wire off while hot, had the engine running and the niddle sat half way up the gauge, where it should bur as soon as i conected it again it shot straight up again Quote Link to comment Share on other sites More sharing options...
