O/S/F Electric Window Fault
Guest mataus30
Guest mataus30
Hi i am new on the site and i could really do with some help i have an M reg cabby and the o/s/f electric window makes a knocking noise and stops an inch from the top. Please can anyone help.
Sounds like part of the winder mechanism may be loose or the adjustment points.
I would take the panel off first and check that.
Check for damage too. Maybe teeth have sheared etc.
mine done the same it'll be the teeth
either take it out and get someone to weld it up and re-cut some new teeth (thats what i done)
or buy one from ebay/breakers and replace it.
