Can Anyone Check Tps For Me .......pleez !
Guest macabrio
Guest macabrio
Please can someone with an EFi tell me thier readings from the TPS with a multimeter, i.e idle volts and WOT volts cant find info on EFi models anywhere :throw:
Guest markeyboy
i dont know about the voltages you should be seeing at different engine states but
the tps is in its basic form a variable resistor, get a multimeter and set it to ohms, what you are looking for is a smooth increase in resistance as you turn the tps
Guest macabrio
Ive done all the checks mate ,even had it in bits , seems to move smoothly enough however it goes from 4.x volts at idle to 0.x volts at WOT i'm sure this is not right thats why i need someone to check thier tps for me :-)
  • 1 month later...
