Need Help Mk4 Power Roof
Guest mk3lesley
Guest mk3lesley
Hello I've just purchased myself a new electric roof kit, however when I've come to fit it, the top pins that attach the rams to the roof are missing. I read in the power roof conversion guide that it is best to use the pins as opposed to using bolts as the bolts will damage the rams. Right then my questions are as follows: can I still buy these from Ford? if not does anyone have a couple spare I could buy? if not what would you's recommend? any help more that welcome cheers
Guest mk3lesley
maybe able to help one in breakers near me
Cool that would be tremendous. I have the ones that came off my manual roof but the ones off the power roof are different. If the breakers has them and you don't mind getting them, let me know how much and I'll send some monies your way
thanks again, Phil.
