Mk 4 Escort Cvh Efi Crankshaft Front Oil Seal Replacement
Guest spaceman
Guest spaceman
What has anyone used to fit the above to engine still in car?
I believe that Fords has a tool for it, have tried using a piece of cutdown waste pipe behind the thrust washer before but never managed to get it to go in properley, someone told me once to use a cutdown coke bottle in the oil pump housing first and then fit the seal inside this then pull the plastic out but not sure about that one.
Surely someone on here has done it at home before?
Thanks
