One Touch Down For All Windows
Guest caffull
Guest caffull
Hi all, iv seen a neat little trick somewhere online but cant seam 2 find it now.
its used a new added switch in the center console behind roof switch & it is a single push button that works all 4 one touch down relays & the same time i can only imagine its 4 diodes connected to the switch
has any 1 ever seen this done.?
i'm also looking to make mine drop me roof at the same time as well i think i can do this with a additional timer relay.
any help would be appreciated
The single push button which you are describing, came as standard on some mk5bs.. mainly the Solar i think.
you can also hold it down and release when you like to open all the windows as much or as little as you like, and you can use it to close all the window back up again!
I think, though dont hold me to this, that if you had the button and an electric roof, i think it did it all.. dropped all windows and then opened the roof.. someone could confirm/deny this..
as for doing it yourself, probably best to get one with wires out of a scrappy mk5b and wire it in..
  • 2 weeks later...
