Heator Blower Stopped Working Escort Cab M Reg
Guest neiloggy1
Guest neiloggy1
hi all i have an escort cab 1.8si m reg 1995,
problem is i got in the car this morning started her up put the heator on setting 3 as usual and nothing happens
i have tried on all settings and nawt, im confused it was working fine yesterday,
i have also noticed that the temperature gauge works sometimes but sometimes it doesnt,
i have also noticed [lol] a pool of water collecting in driver footwell could this be my problems???? please help im usually good with engines but wiring not so good,again please help as its getting colder BBBRRRRRR,cheers neiloggy [new cabby owner]
Guest Cabbytech
Water in the footwell is not good, you may have a leaking windscreen seal, or a hole in the bulkhead letting in water, a poor roof seal across the top of the screen, or a poor weather seal rubber around your door, the problem with water getting in on the drivers side is that the fusebox is located under the dash at this side of the car,
I would first of all check that the fuse for the blower has not simply blown, it is fuse no 14 and should be 20A, if the fuse is ok, you need to find relay R26, this is the ignition relay that supplies the fuse via the ignition switch. If the fuse has blown, and it is the correct 20A one, then some investigation work will be required to find out why the fuse has blown.
i hope this helps.....
Guest neiloggy1
will try suggested advice this afternoon cheers m8 much appreciated ,erm seal across roof ok door seal ok but when you open door it drips straight in gonna have a look for water tracks l8r cheers,
Guest neiloggy1
no rust or holes in bulkhead absolutly solid car been garaged most of its life,all seals look ok screen solid and waterproof,
no fuses have blown relays look like new no water or rust on connections but thwe waters coming from somewhere ????
floor on drivers footwell wet ???? checked fuses for blower heator ok, where do i locate the motor to test it works
