Guest zimmerframe1 Posted September 8, 2008 Share Posted September 8, 2008 hi can any pne help bought a mk6 cabby the motor leaks which i can sort the motor works great of a battery direct any ideas and where are the relays and what colour are the and are there any common faults to look for ? thanks karl Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 9, 2008 Share Posted September 9, 2008 there are a coupple of relays located to the left of the pump, there tucked inside the car clipped to the internal bodywork, ya have to stick ya hand behind to get at em. they are green, you should also find a thermal cutout (looks like a big shiny fuse) Link to comment Share on other sites More sharing options...
Guest zimmerframe1 Posted September 9, 2008 Share Posted September 9, 2008 there are a coupple of relays located to the left of the pump, there tucked inside the car clipped to the internal bodywork, ya have to stick ya hand behind to get at em. they are green, you should also find a thermal cutout (looks like a big shiny fuse) what other faults could there be ? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 9, 2008 Share Posted September 9, 2008 sticky fuse, broken wire, bad earth, knackered switch, Link to comment Share on other sites More sharing options...
Guest zimmerframe1 Posted September 10, 2008 Share Posted September 10, 2008 right ill start with the relays then switch wich fuse is the roof one any idea Link to comment Share on other sites More sharing options...
