Guest luckda Posted May 12, 2008 Share Posted May 12, 2008 Suns out and I really need to get this fixed. I will need to top up the hydraulic fluid. Does any one have any recopmendations of what fluid to use and where this can be purchased. If it is empty how much does it take to fill up Link to comment Share on other sites More sharing options...
Guest Eggsy Posted May 12, 2008 Share Posted May 12, 2008 The cog kit is available in the merchandise section of the club. undo the pump from the chassis & split it (torque drives) replace the cog, as for the fluid people use different 1's but I got some from fords for about £18 & used a syringe to fill the bottle back up, there should be a marking on the bottle. then unlock the pump so you can take the roof up/down manually a few times then lock the pump back up (should be a little nut bolt you can trun by hand) You may have to help the roof up & down the first couple of times whilst pushing the button. hope this helps Eggsy Link to comment Share on other sites More sharing options...
