  4. The middle path is the one most people end up on: own a core block sized to demand you are confident about, and lease the volatile part on top. That way you are not paying rent forever on baseline capacity and not gambling capital on growth that may not happen. Terms on leases run from a month to a few years, so you can match the term to how confident you are. We rent our elastic capacity from InterLIR Global https://interlir.global/ , and own the baseline outright. Fair warning about scaling down: it is easier in theory than practice, because renumbering customers off a range is nobody's favorite project. Also size your owned block with a little headroom, buying a second small block later is more painful than buying one properly sized now.
  5. Good morning. We are weighing renting address space against buying it and the discussion in our team has gotten circular. The rent side argues no capital outlay and we can scale down. The buy side argues we are paying forever for something we will never own. Our usage is genuinely uncertain, we might double next year or we might not. Nobody here has done this at scale before. How do teams with unpredictable growth actually decide, and is there a middle path? We are around two hundred servers today, and the honest answer about next year is that nobody in the company knows.
  6. It works, and honestly it is the standard approach for exactly your situation. You get a local +994 number that rings through to wherever your team already sits, so from the prospect side you are a local business and from your side nothing changes. Setup is minimal: you point the number at your SIP endpoint or a softphone and you are live the same day. We use HotTelecom https://hottelecom.biz/virtual-number-of-azerbaijan.html , for our Baku facing line and it has been steady. One honest note, some carriers restrict outbound caller ID display, so confirm what you are allowed to present before you build a whole campaign on it. Tip: test the forwarding path from a few different local carriers before you hand the number to your sales team.
  7. Hi folks. My company is expanding sales into Azerbaijan and we hit an obvious wall: local prospects do not answer calls from foreign numbers, and the ones who do assume we are a scam. We have no office in Baku and no plans to open one this year, so a physical line is out. I keep reading about virtual numbers with local prefixes but I do not understand the practical side. Does this actually work for outbound sales, and what does the setup involve on our end? Team is five people in sales, all remote, so whatever we pick has to work without any office hardware at all.
  8. Good afternoon! Start with the link for the exact recording you want, and note its album, duration, and any live or remaster label. Spotiget's Spotify downloader reads the linked metadata and matches a recording from other open audio sources; it does not extract the protected stream itself. That makes a quick listening check useful before you organize the file. Compare the opening, running time, and whether there is audience noise. Embedded tags and artwork help with sorting, but they are not a substitute for checking the audio when several versions share a title.
  9. Hello! I'm preparing a reference folder for a music discussion, and one song has both a studio cut and a live version. Their titles are nearly identical. How can I avoid ending up with the wrong recording when I turn a public track link into an audio file?
  10. Yesterday
  11. Rough sequence: define your requirement, get matched to available blocks, run due diligence on the block and the seller, sign, fund escrow, submit the transfer to the registry, wait for approval, then announce. The delays almost always come from two places, incomplete documentation on the seller side and needs justification if your registry requires it. Neither is fast to fix mid process, which is why the pre checks matter. We chose to Buy IPv4 addresses safely , with IPv4.online handling the registry coordination, and the RIPE step took about ten days. Tip: have your LIR contact details and authorization sorted before you start, that trips people up constantly.
  12. Good afternoon. We are building out permanent capacity for a data center project with a ten year horizon, so this is not a temporary need. Everything I read says buying is the right call for that timeline, and I agree in principle. What I do not have is a clear picture of the process itself. Who does what, in what order, how long each stage takes, and where the delays usually come from. Can someone who has been through a purchase walk through the sequence? I am the one who has to present the timeline to the project board, so vague estimates are going to get me in trouble.
  13. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  14. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  15. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  16. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  17. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  18. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  19. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  20. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  21. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  22. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  23. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  24. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  25. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  26. This page is for those who are seriously interested in DEUS DIVITIARUM BROTHERHOOD OCCULT fraternity. People with prejudices and the mob should stay away from here: they would only toddle in darkness and be highly indignant. The described black magic rituals are not without danger and are consequently unsuitable for people who are not mentally in good constitution. Take heed to follow all instructions the way they are described. Without the necessary precautions every ritual will turn to your disadvantage, confusion and total destruction. On the contrary, by following the instructions with precision, you will achieve a complete success in all your enterprises. +2348149784490 Many today are seeking to join a secret society, the one that will give them back their hope and help them to achieve all the things they have wanted in life. They realize that they have lost their dreams and their ambitions. They have settled for a life of mediocrity. Sadly, many are disappointed, for real secret societies are rare, hard to find and even more difficult to join. The more well known have, over time, lost their own secrets and present merely a facade of mystical mumbo-jumbo without possessing any real substance.+2348149784490 There are no accidents and it is no coincidence that you have been led to The TEMPLE OF DEUS DIVITIARUM BROTHERHOOD. The Brotherhood reaches out to help you and to offer the hand of friendship and hope. CONTACT SPIRITUAL GRANDMASTER NOW for YOUR ENQUIRIES +2348149784490 DEUS DIVITIARUM Brotherhood knows that everyone has great potential but often they have lost their self-esteem and their desire for a better life. All of us know that we can be better than we are. We are not living up to our potential. Yet we have this fear to take chances, to venture into unfamiliar enterprises and territories. +2348149784490 divitiarumbrotherhood@gmail.com #secret #occult +2348149784490 The fact your ancestors died poor doesn't mean you've lost all it takes to maintain a luxury life here on Earth. All is possible here on Earth if you know what to do and how to do it, either Spiritually or physically the most important thing is for you to get the result you need which is #WEALTH #POWER #PROTECTION. +2348149784490 OFTEN MANY HAS VENTURED INTO SPIRITUAL MEANS OF ACQUIRING LUXURY BUT ONLY FEW GET TO THE PEAK WHEN IT COMES TO SPIRITUAL WEALTH & LUXURY NOT BECAUSE THEY ARE SPIRITUALLY INFECTED OR UNWORHTY BUT IT'S ON CLEARER VIEW TO THE HUMAN WORLD NOW TO ACTUALLY KNOW THAT IT TAKES A GREAT SACRIFICE AND OFFERING TO PIERCE THE HEART OF THE SPIRITUAL WORLD IN ORDER TO MAKE A RFEQUEST NOT JUST TO MAKE A REQUEST BUT TO GET ANSWERS AND POSITIVE RESPONSE FOR THE SPIRITUAL GUARDIANS OF AGE. WE THE INITIATE MEMBERS OF DEUS DIVITIARUM BROTHERHOOD HAVE BEEN ABLE TO GAIN A SPIRITUAL CLOSE GUARDED SECRET OF ACQUIRING WEALTH POWER & PROTECTION FOR THE GUARDIANS OF AGE THROUGH THE ORDERS OF THE TEMPLE GRANDMASTER AND OTHER SPIRITUAL LEADERS OF THE GRAND LODGE +2348149784490 WE KNOW VERY WELL THAT EVERYONE THINKS THEY HAVE ALL IT TAKES TO BE RICH AND FAMOUS NOT MINDING THE FACT THAT ONLY FEW HAS THE ABILITY AND GRACE TO BE WEALTHY, BECAUSE IF MAKING WEALTH WAS THAT EASY EVERYONE SHOULD HAVE BEEN WEALTHY BY NOW. MAKING ENQUIRIES TO JOIN US HERE MIGHT BE OPEN FOR EVERYONE BUT NOT EVERYONE IS ACCEPTED AT THE END OF THE DAY. DEUS DIVITIARUM BROTHERHOOD OCCULT IS NOT FOR THE RICH OR POOR BUT FOR THE "DESTINED TO BE RICH" IT DOESN'T MATTER WHERE YOU ARE COMING FROM OR WHO YOU THINK YOU'RE, ONCE YOUR DESTINY MATCHES THE SPIRITUAL HEART OF THIS OCCULT YOU'RE CERTAIN TO BE ACCEPTED AND TRANSDFORMED FROM POOR TO RICH OR RICH TO RICHER & POWERFUL. All DEUS DIVITIARUM INITIATE MEMBERS ARE ENTITLED TO EVERYTHING THAT MAKES LIFE WORTH LIVING NO MATTER HOW EXPENSIVE IT MIGHT BE CARS HOUSES LUXURIOUS LIFE BUT ONE THING YOU MUST PUT FIRST IS COURAGE AND BRAVERY BECAUSE THOSE ARE THE KEYS TO UNLOCK TO ONES FORTUNE, AND BEFORE ANY MAN/WOMAN CAN BE ACCEPTED HERE HE OR SHE IS EXPECTED TO HAVE MADE UP HIS OR HER MIND KNOWING THE TASK AHEAD, THOUGH WE DO NOT USE HUMAN BLOOD FOR SACRIFICE BUT DO NOT BE DECEIVED; WE USE ANIMAL BLOOD TO PLEASE THE LORD GUARDIANS OF AGE TO ACCEPT YOU AFTER WHICH YOU'LL BE ENDOWED WITH RICHES AND LUXURY BUT KNOW THAT THERE'S A GRAND PRIZE TO PAY WHICH IS YOU OFFERING YOUR SOUL TO THE LORD LUCIFER AT CERTAIN STAGE ........... NOTHING ELSE WILL BE REQUIRED UNTIL YOUR LAST SACRIFICIAL RITE AND MONEY WILL NOT BE YOUR PROBLEM AGAIN UNTIL YOU DIE. THERE 7 SACRED RULES GUIDING THIS SACRED OCCULT WHICH MAKES IT EASY AND THE BEST FRATERNITY TO BELONG, THIS RULES CAN ONLY BE DISCLOSED TO AN ALREADY INITIATED MEMBER, STRICT MEASURES ARE APPLIED IN TERMS OF KEEPING THE SECRETS OF THIS GREAT OCCULT WHICH INSTANT DEATH, SO IF YOU KNOW YOU CAN'T KEEP SHUT WHEN THE CLOSE GUARDED SECRETS ARE BEEN GIVING TO YOU DURING YOUR INITIATION RITUAL; DO YOURSELF GOOD BY STAYING AWAY OTHER THAN BRINGING CALAMITY UPON YOURSELF AND HOUSEHOLD. THE DUES DIVITIARUM BROTHERHOOD WAS FOUNDED IN INDIA BY AFRICAN BROTHERS WHO TOOK DECISION TO CHANGE THE COURSE OF NATURE IN OTHER FOR LIFE TO BE EASY IN THE EARLY DAYS OF ALLAQUATHAMIN, THERE BY MAKING THE HOME OF THE LORD DIVITIARUM TO BE IN AFRICA, WE HAVE OUR TEMPLES HERE IN AFRICA OF WHICH THE GRAND LODGE TEMPLE HQ IS SITUATED IN A HIDDEN LOCATION IN ASABA DELTA STATE NIGERIA. MANY INDIVIDUALS HAS TAKEN THE RISK OF ATTEMPTING #I_WANT_TO_JOIN_ILLUMINATI #I_WANT-TO-JOIN_THE_FREE_MASONS #I_WANT_TO_JOIN_ODD_FELLOWS AND MANY OTHER SEARCH REQUESTS; THOUGH THERE'RE OTHER FRATERNITIES LIKE MENTIONED ABOVE BUT THE BAD NEWS IS YOU CAN NEVER BE LINKED TO ANY OF THIS OCCULTS BY ANYONE UNLESS THEY WANT TO GIVE YOU FALSE HOPES THEREBY EXTORTING FROM YOU. BECAUSE THE ILLUMINATI, FREE MASONS, ODD FELLOWS AND OTHERS WILL COME FOR YOU ONLY WHEN YOU'RE RICH AND FAMOUS, IN OTHER TO USE YOUR INFLUENCE TO GET TO MORE FAMOUS AND WEALTHY INDIVIDUALS AND SECONDLY THESE FRATERNITIES HAS THERE COUNTRIES AND CONTINENT WHERE THEY ACCEPT PEOPLE ...E.G EUROPE ASIAN NORTH-AMERICA E.T.C. AFRICA IS BELIEVED TO BE THE BLACK SHEEP OF THE CONTINENT THERE BY DISREGARDING WHATEVER CONCERNS AFRICA APART FROM EXTORTION AND ILLEGAL EXPORTATIONS OF MAMA AFRICAS MINERAL RESOURCES; THE DEUS DIVITIARUM BROTHERHOOD OCCULT ACCEPTS ANYONE HENCE YOU'RE HUMAN AND YOUR DESTINY MATCHES THE SECRET HEART OF THIS BROTHERHOOD IN ADDITION YOU'VE GOT TO HAVE THE HEART TO DO WHATEVER IT TAKES TO BECOME ONE OF US NOT MINDING YOUR ANXIETY & FEARS. BECAUSE OF FRAUDULENT ACTIVITIES WE,VE SEALED EVERY ONLINE ENQUIRIES THROUGH FALSE AGENTS OR FALSE CONTACTS PRETENDING TO BE COMING FROM THE DEUS DIVITIARUM BROTHERHOOD'S TEMPLE MEDIA, FOR THIS REASON IT'S NOW ON THE DECISIONS OF THE TEMPLE GRANDMASTER TO ACCEPT, CONFIRM & CERTIFY ANY INTERESTED INDIVIDUAL WHO HAVE DECIDED TO JOIN THIS BROTHERHOOD UNDER THE SPIRITUAL GUARDIANS OF THE SPIRITUAL GRANDMASTER CHIEF SIMON OGBUAKU...... IF YOU'RE STILL OUT THERE THINKING ON #HOW #TO #JOIN #OCCULT #FOR #MONEY #RITUAL WORK-PROMOTION BUSINESS-GROWTH JOB-PROMOTION FAME POWER WEALTH POLITICAL APPOINTMENT AND OTHER GOOD THINGS OF LIFE CONTACT TEMPLE GRANDMASTER TODAY FOR ENQUIRIES TO KNOW IF YOUR DESTINY WILL BE ACCEPTED HERE
  27. In a world filled with uncertainty, many seek protection, spiritual strength, and a deeper sense of purpose. Unfortunately, some pursue these desires through paths that lead to fear, doubt, or harmful practices. There is a better way. +2348149784490 ‎ ‎The DIVITIARUM BROTHERHOOD OCCULT offers a different path—one rooted in spiritual empowerment, protection, and personal transformation. We guide individuals who desire not just material success, but inner power, divine covering, clarity, and control over their destiny. +2348149784490 ‎ ‎Our brotherhood stands apart. We have eliminated all forms of human sacrifice, focusing instead on spiritual discipline, awakening, and self-mastery. Through our teachings, members gain access to deeper knowledge, protection against negative forces, and the strength to rise above limitations. +2348149784490 ‎ ‎Initiation requires a personal sacrifice, revealed by our Grandmaster—symbolizing your readiness to embrace growth, responsibility, and transformation. This is not about money or empty promises, but about true commitment to your spiritual elevation. +2348149784490 ‎ ‎We do not charge for membership. You only provide the required items for your initiation, reflecting your dedication to your own journey. ‎ ‎If you are ready to walk a path of power, protection, and higher purpose, reach out to our Grandmaster: +2348149784490 ‎Your transformation begins with a decision. Are you ready to step into your true power?
  28. In a world filled with uncertainty, many seek protection, spiritual strength, and a deeper sense of purpose. Unfortunately, some pursue these desires through paths that lead to fear, doubt, or harmful practices. There is a better way. +2348149784490 ‎ ‎The DIVITIARUM BROTHERHOOD OCCULT offers a different path—one rooted in spiritual empowerment, protection, and personal transformation. We guide individuals who desire not just material success, but inner power, divine covering, clarity, and control over their destiny. +2348149784490 ‎ ‎Our brotherhood stands apart. We have eliminated all forms of human sacrifice, focusing instead on spiritual discipline, awakening, and self-mastery. Through our teachings, members gain access to deeper knowledge, protection against negative forces, and the strength to rise above limitations. +2348149784490 ‎ ‎Initiation requires a personal sacrifice, revealed by our Grandmaster—symbolizing your readiness to embrace growth, responsibility, and transformation. This is not about money or empty promises, but about true commitment to your spiritual elevation. +2348149784490 ‎ ‎We do not charge for membership. You only provide the required items for your initiation, reflecting your dedication to your own journey. ‎ ‎If you are ready to walk a path of power, protection, and higher purpose, reach out to our Grandmaster: +2348149784490 ‎Your transformation begins with a decision. Are you ready to step into your true power?
