Sign in to follow this
Guest Turbo-bob
Mk4 Zetec Conversion
Guest Turbo-bob
post-6176-1183915729_thumb.jpgWel there i was wondering if anyone could help me? Ive recently fitted a Rs1800 block an loom into my Mk4 with the intentions of turboing it when i get the normal injection engine running properly. The problem i have now is my engine is fitted and ready to go all but the 8 wires on the conector block from the fiesta loom. Im running an '88 loom in the car. Can anybody tell me what these 8 wires do and how you connect it up? Many thanks Bob
Share this post
Link to post
Guest turbosy
I've done exactly this about 5 years ago..........i'll have a think & look in various haynes then get back 2 u.
SY
Share this post
Link to post
Guest turbosy
if i get this right you want to use a 88spec car loom and a fester engine loom? then mate them together?
Thats how i understand it, it can be done.
On the engine bay loom, which includes the ECU, there is a big black plug with 8 wires on it. Theres a permanant live, a switched live, an earth or 2, 1 for the fuel pump (which u don't use), & 2 that go to the coil wires (the coil is made redundant as is the dizzy). The other 1 or 2 wires don't need connecting, iirc!
I'll dig around and get the exact colours and where they go
SY
Share this post
Link to post
Guest turbosy
was thinking about fiesta turbo loom joining in i need to know that myself
Same sort of thing m8, pretty easy!
Share this post
Link to post
Guest Turbo-bob
SY
Share this post
Link to post
Guest Turbo-bob
cheers that would be a great help been up to my eyeballs in wiring diagrams for weeks and just cant figure out the colours. itching to get it out before the end of the so called summer lol.
Share this post
Link to post
Guest Turbo-bob
well there youre fiesta turbo loom shouldnt be to hard done as it very similar to the escort one ive done a lot of work to both unfort the zetec loom doesnt even use the same colours of wires relays etc!!
Share this post
Link to post
Guest Turbo-bob
yep thats the plan its an 88 spec 3i loom and a fester 130bhp 1.8i 16v zetec loom i want to join it to ive heard of it being done just dont know wat the wire colours on the fester multiplug are for.
Share this post
Link to post
Guest dodge69
I've just finnished the same conversion on my mk4 van last week. i wrote down what the wires do so i'll find my list and post it up if no one else has by the time i find it.
Share this post
Link to post
Guest dodge69
found it. mine had 9 wires in a 12 way plug but it might be of some help anyway.
pin 1 - brown - earth
pin 2 - green - rev counter
pin 3 - brown - earth to fuel pump relay
pin 4 - black - ignition live (i think) not 100% sure but thats what mines hooked to
pin 5 - black/red - ignition live for lamda sensor
pin 6 - red - Permanant live
pin 7 - brown/green - oil presure light
pin 8 - black/green - Ignition live for engine sensors
pin 9 - brown/white - water temp gauge
pin 10 - empty
pin 11 - empty
pin 12- empty
I'd double check this before you wire any of it up and don't blame me if it blows anything up but this is how i wired mine and it all seems to work fine.
not sure if you might have to use a water temp sensor from a CVH as i dont think my temprature gauge is quite right.
Share this post
Link to post
Guest Turbo-bob
Share this post
Link to post
Guest Turbo-bob
youre a legend cheers very much youve made me a very happy man! if youre having temp problems some of the zetecs came with a temp switch in the top radator hose as well as one in the thermostat housing the fiesta zetec had one. dat might help the problem. You wouldnt be able to tell me what altenator bracket you used as my engine had been fitted with power steering and i dont know if ill have to change it. thanks again.
Share this post
Link to post
Guest dodge69
my engine didn't have power steering so i just used the alternator bracket that was already on it. i think its the same one for any zetec xr2i/rs1800 without power steering. its the one that sort of hangs under the front engine mount. i also used the extra front engine mount from the fiesta by "adjusting" the inner wing a bit with a hamer, cutting a bit of the mount and welding some nuts into the chasis rail.
Share this post
Link to post
Guest turbosy
Or just use the pulley & alternator off a MK4 CVH.
Share this post
Link to post
Guest turbosy
With no body work!!!!
Share this post
Link to post
Guest Turbo-bob
cheers didnt know dat would work hav a new cvh altenator so might as well get the use out of it cheers.
Share this post
Link to post
