Avo Coilovers
hi dan ive got avo evo adjustable suspension kit fitted to my mk 4 cab , personalyy i wouldn't by them again id buy a set of koni or another brand , they rust baddly if you dont keep them covered in greese then they use metal height adjusters wich also rust so making it impossible to s#adjust the ride height, ordered new ones and they come in black plastic so must be a designe fault, and when you attened the car shows do you ever see any one from avo no stalls no one to ask advise from, maybe im the only one that thinks like this , but thats my advice to you from experiance with avo. hope this helps. andrew f40 cab
thanks Jon and Andrew.
At he mo I have the AVO road sports suspension with 50mm drop springs (more like 60mm with the added weight of a cabriolet) and a front 1 has started to leak, so im going to get FITP out the way first before I phone up who I got them from cuz you know I'll have to strip it down and send that 1 strut back.
Would like to go coilovers but maybe i'll try diffrent springs first and see how that feels.
Thanks again for your input and I'll keep you posted on how things go :smile:
