Guest Daz Posted January 5, 2006 Share Posted January 5, 2006 need to know if there is anywhere in a mk4 dash where I could fit this there's nowhere on a mk3 so I'm hoping that I may be able to take a part of the mk4 dash & adapt that to fit ino the mk3. anyhelp or advice would be great. Cheers, Daz. Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted January 5, 2006 Share Posted January 5, 2006 only place i can thing is the center consoul,,or the heater vents in the middel and re routing them else where ,,, Link to comment Share on other sites More sharing options...
Guest Lee-s Posted January 5, 2006 Share Posted January 5, 2006 i wouldn't put it in the centre console as its to low down and hurts your neck and the heater controls are different on the mk3 dash why don't you build a housing where the centre speaker is on the top of the dash that way if you was to ever sell the car you can change it back to standard Link to comment Share on other sites More sharing options...
Guest Daz Posted January 5, 2006 Share Posted January 5, 2006 i wouldn't put it in the centre console as its to low down and hurts your neck and the heater controls are different on the mk3 dash why don't you build a housing where the centre speaker is on the top of the dash that way if you was to ever sell the car you can change it back to standard <{POST_SNAPBACK}> that's how it is at the moment, but I want it to look as factory as possible, so I'm looking for a mk3 dash to cut up & try & mount it where the centre vents are. Link to comment Share on other sites More sharing options...
Guest sexy-aRSe Posted January 6, 2006 Share Posted January 6, 2006 What is it Daz? I can't see the pic at work its blocked Link to comment Share on other sites More sharing options...
Guest Daz Posted January 6, 2006 Share Posted January 6, 2006 it's a 7" touchscreen monitor 130mm x 190mm Link to comment Share on other sites More sharing options...
Guest sexy-aRSe Posted January 6, 2006 Share Posted January 6, 2006 it's a 7" touchscreen monitor 130mm x 190mm Ooooh thats quite big, not sure if it would fit in the heaters would it. Here is a pic of how my normal screen is mounted, not sure what size it is lol But its not 7" i know that lol http://ccgi.escortcabrioletclub.co.uk/foru...cmd=si&img=2533 Link to comment Share on other sites More sharing options...
Guest brendanj9554 Posted January 6, 2006 Share Posted January 6, 2006 i have one fitted in place of my coin tray, i looked in the yellow pages for dashboard resin repairs, called them out told them i wanted it on an angle facing slightly upwards and they moulded the dash to fit the screen on the angle, and it looked great (since then car has been robbed) Link to comment Share on other sites More sharing options...
