Guest Daz Posted October 16, 2005 Share Posted October 16, 2005 does anyone know how to remove the lenses from the housings on my mk3 cab? tried as few things but they keep on cracking. Cheers, Daz. Link to comment Share on other sites More sharing options...
Chris Posted October 17, 2005 Share Posted October 17, 2005 If you men remove the light cluster from the car....4 bolts inside, and then it should just fall out the frame, if not lift it up slightlly Link to comment Share on other sites More sharing options...
Guest Daz Posted October 17, 2005 Share Posted October 17, 2005 If you men remove the light cluster from the car....4 bolts inside, and then it should just fall out the frame, if not lift it up slightlly <{POST_SNAPBACK}> no I mean to acually seperate the lenses from the light unit itself Link to comment Share on other sites More sharing options...
Chris Posted October 17, 2005 Share Posted October 17, 2005 In that case you need a sharp stanlly knife and a lot of patients, to trim round the edges Link to comment Share on other sites More sharing options...
Guest Keith Posted October 17, 2005 Share Posted October 17, 2005 Try using a bit of heat to warm the glue up and, as Chris said, get a really sharp knife into it to cut the glue out. Link to comment Share on other sites More sharing options...
Guest Carl Posted October 17, 2005 Share Posted October 17, 2005 last time i did summats similar, i used a small metal cutting disc on my dremel, works a treat & is easy to manoeuvre Link to comment Share on other sites More sharing options...
