jimpoole Posted April 11, 2022 Share Posted April 11, 2022 Hi! I've got an issue with the wiring on the roof of a 1990 XR3I. The wiring which I can find is consistent with the early roof wiring in the diagram given in the tutorials section, however, the brown/blue wire which provides the ground for the two boot mounted relays disappears into the loom and I can't find the other two relays and the two switches. Does anyone know where these relays are and what the two switches are? I've looked behind the drivers kick panel and behind the instrument cluster but can't find them. Quote Link to comment Share on other sites More sharing options...
