Glewy Posted June 8, 2020 Share Posted June 8, 2020 Hi. I have an Xr3i cabriolet 1988. ever since I bought this in 2015 it has had a slight battery drain. it’s ok day to day but if left for about 10 days it goes flat. New battery was fitted. I have noticed last night when connecting the charger a relay clicked in the fuse box. Then carried out battery drain test with relay connected and disconnected. This appears to be the problem. As is constantly activated. relay V is for excess voltage protection, fuel pump and dim dip lighting. just wondering if this should be constantly live and where the feed should come from. thanks. Quote Link to comment Share on other sites More sharing options...
Vincygav Posted June 10, 2020 Share Posted June 10, 2020 Could it be an aftermarket alarm/immobiliser wired up Quote Link to comment Share on other sites More sharing options...
