DaveH Posted December 6, 2019 Share Posted December 6, 2019 Hi all I have fitted a new complete clutch including cable and ratchet to my mk4 cabby, the problem i was having was i had to put the pedal to the floor to get it in gear. since i have don the work the ratchet keeps slipping i know its not the ratchet because it was doing it with the old one, thats why i replaced it any ideas/help would be realy appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Himanshu Posted December 29, 2019 Share Posted December 29, 2019 What make is the clutch and was it genuine Ford parts cable, and ratchet/ pawl assembly you used? Check the fork arm at the gear box housing, I just replaced my cluthc with a LUK, and original Ford cable, and ratchet and Pawl, but found it was an internal gearbox issue. Luckily I swapped the gearbox (as I had a NOS gearbox and all is fine now! But oringinally I used Q&H and it was so poor. I lost out on the labour Q&H after a year refunded me with the money but it had done damage to the gearbox. Quote Link to comment Share on other sites More sharing options...
