Nick Barnes Posted June 13, 2019 Share Posted June 13, 2019 I have a MKVII 1997 there are some rust spots under the strip, where the bodywork at the rear joins the moulding strip that holds the rear / bottom of the roof, and that the tonneau cover fixes to with 5 fixing pins. How do i remove the strip to repair / repaint the bodywork ? I can only see screws at the end by the Rear Quarter Window ? on the outside are there any more on the inside ? Does it just pull off ? What else holds it in place ? Are the pins that the tonneau cover clip onto fixed to the bodywork and if so how do they come out ( plastic coated so I do not want to try and grip them to twist them ? ) Thanks for any advice Nick Quote Link to comment Share on other sites More sharing options...
sifitz Posted June 13, 2019 Share Posted June 13, 2019 Put the roof down lift the rubber trim in the inside were the studs are unbolt all the studs and remove them then the rubber trim can be removed Quote Link to comment Share on other sites More sharing options...
Nick Barnes Posted June 13, 2019 Author Share Posted June 13, 2019 Thanks for your help lets hope not everything is rusted underneath there's only a couple of spots at the moment showing and hopefully I can stop it getting worse. Quote Link to comment Share on other sites More sharing options...
