No power steering to Power Steering
You can fit a hydraulic pas as ford did fit it to a special order but these are very rare as you will need a pump ,pipework and rack an easier way is to fit an electric pas which is from esortmk2mania they use corsa b electric pas and modify the steering column so all you need to do is send them your old column and bolt it in and wire it up search google (ford escort mk3 pas)
Link to post
