Sign in to follow this
Aisgeir
An extra Inch!!
Hello
Recently acquired a lovely little 91 escort cab in red. The electric  roof is in excellent condition with two small hiccups.
It doesn't work
It doesn't shut.
I haven't got into the motorised side of it and I'm not too fussed, I'm more bothered that I cannot close the roof, there is about 2-3 inches that the hood needs to go forward to reach the top of the windscreen. How is this adjusted so that it will close?
I perused through the many posts and tutorials which are all fantastic but couldn't find anything specific to my concern
Any help appreciated.
Thanks
Share this post
Link to post
So I've managed to get the roof to reach the forward clamps, by extending the hooks a good few turns.
I've also loosened all the mounting bolts and disconnected the hydraulic rams and tension cables.
Although the roof is now closed it is still short an inch or two.
I've been applying vinyl conditioner to the top as I think as the roof has been open for a long time that it may have stiffened up so I'm hoping if I keep tightening the clamps a turn a day that the top will stretch out.
Failing this I'm going to run a ratchet strap from the wheels backwards to the roof frame and slowly tension it to straighten any deformation it may have.
Share this post
Link to post
Had the same on my mk5 when i got it. If its vinyl i think it may have shrunk, mine did.
I tried everything but ended up buying a complete second hand roof for £120 in the end. (mohair this time)
Share this post
Link to post
you will notice the difference when opening and closing the vynel roof on a cold day to a hot day . just be very careful not to over stretch them handles other wise you will end up snapping them  :<(
regards ollie
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
