Problem with windows when close the door
el_cube
On 17/10/2018 at 22:21, Paul Grainger said:
Hola. Saque el recorte de la puerta y eche un vistazo. La parte inferior del corredor de la ventana está asegurada al marco de la puerta cerca de la parte inferior y es ajustable. Esperemos que solo sea el tornillo de seguridad que sale.
Aclamaciones
Pablo
I will try it. Thanks so much, Paul.
Álvaro.
  • Admin
did you get it sorted ?
remove the door cards and there is a bolt that with slight adjustment drops the window . make sure it catches the seal though as to much and you will get a draft
if you have a workshop Manuel it does show pics
regards ollie
