Fjaimo10
1990 h plate xr3i cabrio restoration
Purchased it begining of august and whilst amazing solid no rust or welding the arches are like new needs a respray and tidy up and engine running rough coolant leaks new roof and frame needs attention maybe replace
Share this post
Link to post
Nice one , put some pictures on of restoration
Share this post
Link to post
Lookin forward to see the Resto pic's
Personal I'd go standard
But good luck with the Resto
Share this post
Link to post
Thats all thats on slam panel as chassis plate was rusted away leaving only chassis number and the orther plate only had thoose numbers on it or does anyone know colour thanks
Share this post
Link to post
Work on hold at minute building timber frame extension on back of garage to store all stripped items so till that done cant strip but had a bit of look round
Original engine
All original panels
All glass apart from screen original etched
And solid as far as i can tell
No filler anywhere
Never had anything against it hpi
Drivers seat wont tilt
Frame snapped a joining pin (can these be repaired) look like pressed in
Radiator leaking
Probably alot more
So do i keep original or mod
Share this post
Link to post
Looks, half modded already, I have just bought another and gonna modify it, saying that I do have nice original tennis I owned for sixteen years.
Share this post
Link to post
Down to you, original factory spec cars worth more money, but its your car and you want it the way you want it.
Share this post
Link to post
Its all about personal opinion to mod or not
But costs play a major part of that decision
What ever you think it will cost will be a mile away from the final cost
Havin very deep pockets will make it so much easier
Good luck with the build which ever way you go
Share this post
Link to post
Makes your heart sink a little when start but will be worth it when its done
Share this post
Link to post
Found a couple of holes in spare wheel well and rear floor so new repair panels ordered
Also if any one has them i need the 2 metal fuel pipes that run under car for efi
Share this post
Link to post
Had a couple of bargains mint roof and frame complete £32 and fully recon roof motor and rams £40 also the 2 corner trims i needed for front doors £25
Share this post
Link to post
Few bits needed below if any one got them prob add more
Fuel cut off in boot
Boot carpet
Rear view mirror
Headlamps
Rear side window j shaped seals
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
