Himanshu 1 Posted August 10, 2018 Share Posted August 10, 2018 I have just had the clutch replaced with a gear box oil change, and it now crunches in every gear, I can only get it into reverse by engaging reverse when car is switched off and then starting it. It was a Quniton and Hazell part, with Mobil SHC 75-90 oil. It ran fine until so called mechanic replaced the 3 part clutch kit and did an oil change to the gearbox. By the way, I decided to change the whole clutch as the rear main crankshaft seal was leaking and release bearing was slightly noisy. Quote Link to post Share on other sites
Ian71 12 Posted August 10, 2018 Share Posted August 10, 2018 They always leak, I have 4 cvh cars and 3 leak there. Quote Link to post Share on other sites
Paul Grainger 6 Posted August 11, 2018 Share Posted August 11, 2018 Sounds to me like the clutch centre disc has been put in the wrong way round. If the clutch now has a stiff spot right at the bottom then do not be tempted to press the pedal too hard or the clutch quadrant on the pedal will break causing you more problems. It is only plastic. Hope all goes well Quote Link to post Share on other sites
Himanshu 1 Posted August 13, 2018 Author Share Posted August 13, 2018 Going into a different garage, but on a cursory look, I saw they had removed the gear selector locking rods, why they did this is beyond me. Do not if you live in the East Midlands, use, Sturgess and Thompsons Ltd, situated on Gypsy Lane, Leicester. I will post updates if it can help anyone else! Quote Link to post Share on other sites
landersd 0 Posted Wednesday at 15:20 Share Posted Wednesday at 15:20 On 13/08/2018 at 17:00, Himanshu said: Going into a different garage, but on a cursory look, I saw they had removed the gear selector locking rods, why they did this is beyond me. Do not if you live in the East Midlands, use, Sturgess and Thompsons Ltd, situated on Gypsy Lane, Leicester. I will post updates if it can help anyone else! i,m in leicester , who did u use in the end Quote Link to post Share on other sites
