Sign in to follow this
Lovejoy
90 spec XR3I Cabriolet
Hi all, I've finally started work on my mums XR3I Cabriolet. Mum got the car in '98 and only used it on nice days, then unfortunately someone tried breaking into the car in '01, luckily they couldnt get in, but mum got paranoid and took it off the road. Its been in dry storage since then, its only covered just under 43k. The plan was to get it back on the road and for my mum to use it but shes not interested anymore so it might be for sale, but the more I look at it and do things to it I'd like to keep it myself 🙂
Heres a few pics,
29799160858_ea09f247e7_c.jpgUntitled by Steve Holden, on Flickr
42766156645_457a068039_c.jpgUntitled by Steve Holden, on Flickr
42766154715_30e4dbd4ae_c.jpgUntitled by Steve Holden, on Flickr
42766152895_0fcb74e414_c.jpgUntitled by Steve Holden, on Flickr
28780970717_06c29456b0_c.jpgUntitled by Steve Holden, on Flickr
43622631532_afbc845d3a_c.jpgUntitled by Steve Holden, on Flickr
So far Ive given it a good clean, the interior ha come up great, it still needs a good polish, but there are a few stone chips/scratches at the front that need addressing, I've been trying to find some paint but I dont know what the colour is called? On the data plate it states PA9 but when I search for this I cant find it? Does anyone know what the colour is called?
I've removed the passenger door lock that was damaged and hopefully today I'll receive a new lock from a guy on ebay who supplies locks to the spare key you provide.
The metal plate inside the 90 spec sill trim on the drivers side has rotted, luckily the actual sill on the car is in great condition, as I've been unable to find any 90 spec trims I'm planning to remake the plate as the actual plastic cover is still in good condition.
Also Im still searching for a pair of Carello 640 spot lights that arnt too expensive!
Its booked in for a service and cambelt change and then hopefully get it mot'd
Share this post
Link to post
Looks a really nice car, well worth the effort to keep it original. Ford fitted other front spots as well as Carello , I am told by couple of members you can still buy them from mini as they were the same as fitted to Mini Cooper of the same era, at last time of asking I believe they were 120 a pair.
Share this post
Link to post
That's looks a very clean car - I'd be keeping that m8
And keep it original
Share this post
Link to post
Im guessing its Radiant red, so will order a touchup stick.
Also my lock arrived, will get pics when its fitted, its booked in on the 20th for the cambelt and any other little bits that need doing, cant wait to drive it 🙂
Share this post
Link to post
Hope the good weather holds for us all
Share this post
Link to post
Have you got your 90 Spec Brackets?
There not cheap if you need them
Share this post
Link to post
Yes I managed to get some a few months ago for £41, I was pleased with that
I went to see the car last night, the garage has done the cambelt, replaced the water pump, and replaced a few brake hoses. They've got a few more things to do but they're working on it between other jobs. Its getting there 🙂
Share this post
Link to post
The only Mod's I'd do to this is
Fit The Corello Front Spot Lights
add a set of Recaro front Seats
and Fit the RS Four Spoke Steering Wheel
That would be Spot on then
I'd Keep the old bits to return it back the way it was if required
Share this post
Link to post
I'll be honest, I don't know much about Fords, just did a google search for the 4 spoke RS steering wheel, its awesome! I think it'll be staying stock for now, I'm guessing the bill from the garage is going going to be quite big! Cheers
Share this post
Link to post
Its mot'd and back. I've moved house in the time its been away, I still need to sort out the 90 spec sill cover on the drivers side, it also needs a new battery which I'll get this week. Im not happy with the new front number plate, so need to order one in the original older style font, it needs detailing too but apart from that its pretty much ready to be used, just in time for autumn!
31199131678_8e693849df_b.jpgUntitled by Steve Holden, on Flickr
Share this post
Link to post
Nice, always look good in red.
Share this post
Link to post
Cheers, yeah the 640’s really finish off the front end. Thanks for the link! I’ll have a bid, cheers!
Share this post
Link to post
£104 for the side trims
I was expecting them to go for more
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
