Fluid Resovouir
jonnwhite
Hi All,
My reservoir is leaking and i can't seem to find a replacement?
There is a crack in the bottom, i've tried soldering iron to close it etc but it hasn't worked.
Is there anywhere i can get a new reservoir or is there another car that uses the same pump?
thanks
  • 2 weeks later...
Posted last year with photos.used a plastic dish via my wife kitchen cupboards with the right size clip,still working on are cab,some say the V/W cab will fit 4me at £40 a pop I say thank my dear wife, if you go this way bleed by lifting roof  slowly with valve open
