Martin
Power roof pump
VW Golf reservoirs also fit and I believe they are still available from VW dealers.
My Si is using a Golf reservoir and it's an identical fit.
Share this post
Link to post
My Si is a 93' mk5b and the reservoir I used is from a 95' Golf. The only difference between the Ford and the VW item, is the VW reservoir holds a greater volume of fluid and is therefore a little deeper (horizontally). Fitment wise it's the same.
I assume your car is a mk5/mk6? If so, all the pumps were the same. Someone please correct me if I'm wrong.
Share this post
Link to post
Hi thanks again for yur help mines a mk4 I’ve been told a mk3 golf cup shud fit but not to sure!
Share this post
Link to post
I don’t think the pumps have ever changed from mk4 up to mk6, the ones I seen are all the same.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
