Paulas Posted September 25, 2017 Share Posted September 25, 2017 Hi all I have recently bought a mk6 and the brake pedel is very firm and takes a lot of effort, is this normal? and if so is there an upgrade I can do so there is less effort? Thank you Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted September 27, 2017 Share Posted September 27, 2017 I had a hard pedal on my mk2 fiesta. Was told the calipers were the problem. Link to comment Share on other sites More sharing options...
Paulas Posted September 28, 2017 Author Share Posted September 28, 2017 Oh ok will have a look into that Thanks Link to comment Share on other sites More sharing options...
Paul Grainger Posted September 30, 2017 Share Posted September 30, 2017 Test the servo is working. Pump the brake pedal so it is hard and then press it and hold whilst starting the engine. When the engine starts the pedal should go down a bit. This shows that the servo is doing its job. If not then it could be a servo fault or a vacuum supply problem. Link to comment Share on other sites More sharing options...
Paulas Posted October 4, 2017 Author Share Posted October 4, 2017 I am away at the moment but will give it a try when I'm back Thanks for info it is really appreciated Link to comment Share on other sites More sharing options...
ianxr3i Posted October 17, 2017 Share Posted October 17, 2017 I am away at the moment but will give it a try when I'm back Thanks for info it is really appreciated I have got a servo from a MK6 if you need one Link to comment Share on other sites More sharing options...
