Brake Servo
Paulas
Test the servo is working.
Pump the brake pedal so it is hard and then press it and hold whilst starting the engine.
When the engine starts the pedal should go down a bit. This shows that the servo is doing its job. If not then it could be a servo fault or a vacuum supply problem.
  • 2 weeks later...
