Mk6 Electric Aerial Problem
SteveGregory
Hi Steve.
Best thing to do is test it first.
Undo and pull back the trim so you can get to the aerial.
Switch the radio on and use a test light or multimeter to check you have a 12v feed at both wires going to it. The earth for it is the small black wire.
These aerials are pretty good at filling up with water and siezing. If this is the case then you could strip and clean. Replacements are around on ebay etc but quality varies.
Hope this is of help.
Cheers
