Anybody Fitted A Relay To Their Rad Fan?
Guest username
Guest username
Just wondering if anyone else has fitted a relay for their CVH cooling fan, to lighten the load on the switch & stop it from failing?
Got to replace the switch on our cabby & I'm thinking of modding the wiring a bit to make it switch a relay instead, as well as adding a manual override and warning light on the dash so I can see if/when the fan switch is activated as well as put it on myself if I think it's failed again. Anyone done similar?
While the car's in bits for the radiator support repair/replacement (the one I got turns out to be wrong, it's deeper!) I thought I'd go over the rest of the engine/bay too so this is one of the jobs on the list.
